RWR CDI wiring Help
Original RWR CDI wiring
Hey guys, I have a RWR CDI, it has been rewired to fit my DSX, simply by pulling the wires and reinserting them into the correct spots. Now however, I need to know the original order the wires are supposed to be in in order to fit on a regular DS. I don't want to know which wires go to which wire on the quad, but rather which order they are in the plug.
Say start from the top left, to the top right, then from the bottom left to the bottom right(looking at the plug from the front). And also make sure you refer to the tab/guide inside the plug, which side that is on.
This would help me out tremendously. Thanks
RWR CDI wiring Help
ALL I COULD FIND WAS THIS FROM ANOTHER FORUM......
If you have the yellow or black standard model (not the Red Viper, Orange Baja, or Black and yellow X), the plug hooks right up. But if you have the Red Viper, Orange Baja, or Black and yellow X, you'll have to use the diagram below to make your connections.
RW-cdi...to...Baja-wiring
red......to...red/violet
white....to...black/yellow
orange...to...white/green
black....to...black
blue.....to...black
green.........not used
black....to...black
blue.....to...black
