Dual carbs and a CT pipe
i work at a machine shop and your problem intregues me
how much space do you need? in my opinion i would cut and flaten the side of the pipe that hits you carb till you had adequate clearance then on the outside of the pipe on the non carb side i would open it up and bubble it out to match the same ammount of space you lost from flattening the inside. i know my description is hard to follow
GregM
Mar 6, 2018 06:53 AM
