Wet or Dry
Dry, as most would expect. No need to purge, keep checking jetting, run safety systems in case that fuel pump fails, no need to worry. What do you want, a system thats pieced together that should work good if you keep an eye on her, or a system that runs consistent, time and time again, that doesnt have a fuel pump, changes in elevation dont have an effect, that has been proven the most reliable system on the market since in introduction, Boondockers, and damn I should be a salesman for these folks, sorry. I run some of the longest hills in the U.S, have ran tons of nitrous through two stock motors, not a single problem, unless speed and satisfaction are problems. Good luck, all systems do the same thing as said earlier, just different approaches. Jed
