swing arm bearing ???
Old Apr 21, 2005 | 04:10 PM
blue250r's Avatar
Default swing arm bearing ???
I was changing a burst tire and tugged on my axel to check the axel bearings while i had it up.
And found a slight knocking noise, I turned out to be the left hand swing arm bearing, probably less than 1 mm of movment. but it still sucks this bike is only a year old and doesnt have that many hours on it it has also been greased every couple of rides.
Its an 04 with the allow swing arm, anyone else had problems ?
Old Apr 21, 2005 | 04:29 PM
DuneRider650's Avatar
I ride a little here and there......
mine was a bit loose so i re torqued the bolt on the outside and it was pefect....the nuts got a bit loose.
Old Apr 21, 2005 | 04:30 PM
Camds650's Avatar
Mine was the same way
Old Apr 21, 2005 | 05:01 PM
blue250r's Avatar
thanks for the replys
Any one know whats in there i checked my manual which is for a 2002 and it looks like is just bushes,
Or are there needle roller bearings?
i will check the tourqe, but i dont see how it being loose would alow play on the bush /bearing, Unless they are tapered ?
Old Apr 21, 2005 | 06:15 PM
blue250r's Avatar
You were spot on.
The lock nut was still tight but the inner nut came up 3/4 of a turn easy before coming tight.
the play must have been the tube moving on the bolt.#
thanks for the help
Old Apr 21, 2005 | 07:08 PM
SCOUNDREL's Avatar
They are tapered bearings. When installing them you have to set a preload torque then back it off and re-apply the torque. This is to set the bearing races in the carrier. Do not shortcut this step even if it seems redundant. Often people will skip this step and later the bearings loosen up.
Old Apr 21, 2005 | 08:07 PM
blue250r's Avatar
scoundrel do you mean the axel bearings or swing arm bearings ?
wendal
Aug 3, 2024 10:03 PM
exmotocrosser
Sep 13, 2019 06:12 AM
fd24
Jan 16, 2019 08:59 AM
jbrewster94
Sep 23, 2015 04:16 PM
Elkaholic
Sep 6, 2015 02:44 PM
