paddal/rim?
Old Apr 26, 2005 | 07:11 PM
2BIG2BFAST's Avatar
Default paddal/rim?
I had my hubs shaved and redrilled so i could also run an 8 inch rim. My ? is running an 8 inch rim i should be able to run alot bigger paddal. By going with those rims and a 6 rib paddal am i losing speed, gaining more power or what. I have a set of the sandsharks on the stock rim so what is realy the difference. Is anyone else running with a 6 ribbed paddal?
Old Apr 26, 2005 | 07:31 PM
04DS650's Avatar
Default paddal/rim?
I think that MrHp was running 6 paddles up the hill at FSW. See if you can find any of those pictures to make sure.
Old Apr 26, 2005 | 07:37 PM
learnem's Avatar
Default paddal/rim?
the smaller the diameter of the wheel, the faster the rev, but the lower the top speed. on that smaller rim, you should be able to get away with 6 paddles, but the nature of the beast is that it is heavy. i ran geckos for awhile, and all i did was get stuck everywhere i went.
Old Apr 26, 2005 | 08:51 PM
2BIG2BFAST's Avatar
Default paddal/rim?
Yes im getting the same setup as mrhp. he is doing my 730 bigbore build. I told him i wanted everything he had on his bike. so with my titanium valves its gonna rev quicker anyway so i might need to check into some different sprocket combos. any help would be apreciated.
