gs1100 motor into a ds650 help!
Old May 1, 2005 | 02:04 PM
che's Avatar
che
Default gs1100 motor into a ds650 help!
im going to put a gs1100 motor into a ds650, and i will sure apreciate all the help you can give me, like if i need to modify my frame, make it stronger, changing the shocks, what should i do. i'm gonna have to cut the frame in the front by the radiator, to be able to fit the motor.
any help you can give me will be cool
Old May 1, 2005 | 02:15 PM
DuneRider650's Avatar
I ride a little here and there......
i think one of the people who have done this is JEFFROE
Old May 1, 2005 | 10:52 PM
wildcard's Avatar
we did a kz 1000 motor in a tecate and started a gs1150 in a quadzilla but came to a very important conclusion, if your gonna do it make it a lot easier on your self and use a newer liquid motor they are way smaller and easier to install and make better power and you can even use a fuel injected motor.
Old May 2, 2005 | 02:31 PM
che's Avatar
che
it's too late cause i already bougth the motor, but thanks
Old May 2, 2005 | 02:37 PM
JEFFROE's Avatar
dstroyer just did one and biggerisbetter also. i bought mine already built (sorry i cheated) but one of these guys should be able to point you in the right direction.
Old May 2, 2005 | 03:32 PM
DStroyer's Avatar
che,
Its a long road my friend. Start with the frame. You have to measure, measure, measure to make sure the sprockets will line up perfectly when done. Watch the pivot tube on the swingarm, it is crucial. Move the motor sprocket 1/2 inch forward or back, and it changes the geometry of the chain considerably. Yes, you will need to cut the frame if you want to do it right. Some get away with just rotating the motor forward, but oiling problems can, and probably will arise from that. Not to mention it will probably look terrible. So, I guess, start with the frame, then motor mounts, then cooling system, then wire harness and fuel. Just my 2 cents.
Gary
Old May 2, 2005 | 04:37 PM
biggerisbetter's Avatar
Their is alot of frame work that goes into these conversions, each motor will be different, so I cant tell you just what and where you will have to cut. First you will need to take some measurements and right them down. On the bottom of the frame Measure from the footpegs to point up front(like the a-arms). after you cut your bottom frame rails out yur frame will flex forward a couple inches. you will need these measurements to refer back once you start fabricating your new bottom frame rails,I dont think you will need to do the top, cause your carbs will hang striaght back, but if need be, you will do the top the same way.
Start their, after you cut out the bottom frame rails bring your engine in from the bottom and jack it up into position. Be mindfull at all timeswhere your shifter, brake lever, exhaust, oil cooler ( if you have one) radiator ( if you have one) will be. Fab up your bottom frame rails, ( remember 2 get back to the origional maesurment you took earlier) then start on your motor mounts.
Bigger.
Old May 4, 2005 | 12:45 AM
che's Avatar
che
thanks for the help guys, ill start by doing that. i really apriciate it [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 2, 2005 | 08:37 PM
che's Avatar
che
i decided to put the motor into a suzuki 230 and im going to buy a newer motor for my ds
EIF
Apr 20, 2017 07:15 PM
mrtidy
Feb 3, 2016 05:00 PM
kodiacrunner
Oct 4, 2015 11:52 AM
Whitelx1
Oct 2, 2015 10:55 PM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
