Got another DS.
Old May 4, 2005 | 02:55 AM
sandbomber's Avatar
Default Got another DS.
Get that 730 kit man, I think its jeffroe that his signature reads (forgiveness is better to get than permission)[img]i/expressions/face-icon-small-wink.gif[/img]
Old May 9, 2005 | 10:03 PM
JMAC650's Avatar
Making some progress on the 03. Checkout pics 8 & 9.
Old May 10, 2005 | 02:41 PM
DSengineer's Avatar
Has been here a long time!
JMAC,
Can you share your cleaning techniques? Do you use a pressure washer, chemicals, etc. You could eat off of those things.
Old May 10, 2005 | 03:56 PM
JMAC650's Avatar
First place it on a stand, remove the tank, plastics, and tires. Sounds like alot but it only takes 15 minutes. Hose it down really well. Spray the whole thing down with simple green. Then I mix some dish soap with simple green in a bucket and use it to wash with. I picked up one of those car wash brushes from kragens and use that with a rag. Once I have it all clean and rinsed off I blow it dry with the compressor and towel dry from there. Then I clean all the parts and tires(same process as DS) and put it back together. My wife calls my **** about cleaning it but I figure it stays in good shape and you can check it over when you are cleaning it. The whole process takes about 2 hours, depending on how dirty. If you check my pics, the one where it is all muddy took almost 6 hours to clean.
Old May 10, 2005 | 04:47 PM
  #15
jackass650's Avatar
what kind of stand you using to keep both front and rear tires off the ground? i want one thanks
Old May 10, 2005 | 04:50 PM
  #16
JMAC650's Avatar
An alum motorcycle stand. Looks like a little stool.
  #17
JMAC650's Avatar
Look at picture 9 in my pictures and you will see it.
Old May 10, 2005 | 06:54 PM
  #18
VEGAS650's Avatar
Originally posted by: dsdrew
Wow thats a steal...around here that would go 5000$$ You cannot find a used DS that isnt junk..
I've got a like new 03 for $4,500.
Old May 10, 2005 | 10:01 PM
  #19
sandbomber's Avatar
JMAC ya must like twins 2[img]i/expressions/face-icon-small-wink.gif[/img] looken good!!!
