04 sprocket hub (HELP)
Ok my 04 sprocket hub is alluminum..i thought it was steel like the older model ds650's, mine is wore out and had spun around on the splines on the axel. We took the hub off and it is junk now...i called some dealers and they said bombardier is back orderd on the part for a month or so....so i was wondering if all the ds650's hubs are interchangable so then i could get a steel hub that would actually last....need help fast if anyone has info please post it.
I wish I could answer for certain, but I can't. 222 knows the answer for sure. But I do believe there are 3 hubs - the old steel, an aluminum that is interchangable with the steel, and another aluminum (I think the nwest) that is different from the other two...but like I said not certain.
I removed my old steel, and replaced with the appropriate alum, but do not know what model year it is, I got it from 222 so he just made sure I got the right one.
My aluminum one has been on for quite some time now, no issues, and I know many a 70 and 80HP machine is wearing them. Seems yours stripping is a real fluke, hard luck.
