DIMM OIL LIGHT ?
Old May 2, 2005 | 08:51 PM
RIPYA's Avatar
Default DIMM OIL LIGHT ?
I changed the oil ,filter,and cleaned strainer..Rode for about 2 hours and noticed the oil light looked to be on, but it seemed to be sunlight hitting it just right.Today in the garage I started it and the light was bright while starting and then when idling the light dimmed but it was on .I cut the on switch and turned over a few times thinking maybe air , but the light was not on at least a couple of hours the day before.. Called the dealer mech. and he never heard of this before? There is no banging around in the motor so I'm hoping no problems there...Also used Bombardier oil and filter...
2004 DS650 [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old May 2, 2005 | 09:18 PM
jackass650's Avatar
wasnt there a write up a week ago or so about the oil pressure switches located behind the jugg and below the intake getting plugged and one guy took his out and put it in a hot pan for a while and pushed a small wire in the hole in the bottom a few times then let is simmer some more in the hot pan, i cant remember how hot it was but he said it has worked fine ever since maybe try a search on the forums read this link oil pressure switch cleaning
Old May 3, 2005 | 07:27 PM
jackass650's Avatar
how did everything work out ripya? let us know
Old May 3, 2005 | 07:45 PM
learnem's Avatar
that happened to me, and it was the oil level. it was just enough to keep the light from going completely on, but low enough to trigger the light. i added about 3-4 splashes, and that solved the problem.
Old May 3, 2005 | 08:21 PM
RIPYA's Avatar
Added oil for the hell of it, then pulled the filter, and cranked it over and oil came pouring out , so there no air...I unplugged the switch and cleaned it , but still lights up.. I'm going to take it to the BOMB mech. and let him tell me that I am flowing oil or not, then I think it's time for some real gauges for oil and water...Also checked for any bare wire spots couldn't find any...I'll keep you posted....
Old May 3, 2005 | 09:46 PM
TheOz's Avatar
The Bomb oil pressure sensors are junk. I've had three on my machine. If they at all get wet, they go bad. I've read where someone pulled it off and let it dry out or heated it up. I can't comment, because I purchased a new one each time. I ordered and installed the Bomb oil sensor condom and haven't had the problem since. I think the rubber cover was < $10. I don't have the part number, the dealer can look this up.
Old May 5, 2005 | 08:26 PM
RIPYA's Avatar
IT HAS BEEN CONFIRMED IT IS A BAD SWITCH, NOT GOING TO ORDER ANOTHER... IT'S TIME FOR SOME REAL GAUGES...THANKS FOR ALL THE SUGGESTIONS !!!
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
