Just finished my 05 headlight conversion and-
hey DS650power14 click on my webshots link and on the parts diagram i beleive they are part number 32 they are little push nuts that hold the pins for the trim in your plastic, does that make sense?
[img]i/expressions/face-icon-small-smile.gif[/img]
yes that makes a lot of sense... but how does it work?
and also, can somebody tell me if their plastic trim touch the light when installed or there is a gap?
#17
Originally posted by: Dingo2
Does anyone know if you can install the new style headlight trim on a 2000 DS with old headlight?
#18
DS650power14,
You NEED to go to a Bombardier dealer and take a look at any DS with the new headlight factory installed - seeing how the factory did it will save your hours of trying to figure it out. Take a camera with you in case you need the extra memory aid. Once I got to see exactly how it was done it was too easy.
#20
Hey: Guys
I am going to be doing the headlight conversion shortly, will my stock rectorfier be enough to power the 2 bulbs. I usually run a high powered Super Plasma GT-X Piaa bulb and will run 2 of them after the conversion.
I have also added a set of after market lights, but they are hooked to the battery directly.
Thanks for the Help
Thanks for the Help
