Dyno Jet v.s Mikuni
Old May 23, 2005 | 08:22 AM
w1ngnut's Avatar
Default Dyno Jet v.s Mikuni
Those Rappy guys are a different breed anyway. We make our raptor buddies stick together in their own little circle...lol[img]i/expressions/face-icon-small-happy.gif[/img]
Old May 23, 2005 | 10:19 AM
SCOUNDREL's Avatar
Originally posted by: w1ngnut
Scoundrel.....there is a diff in the jet #'s. Also if you are using mikuni jets stay with the stock needle. If you plan on running a dj kit, use the dj needle. The needles seat differently in the jets. As long as you don't mix the two you will be ok. I had a dj kit in my ds for a bout a year. I went back to mikunis. The dj needle wore out to quickly. Also the dj jets arent as true as they should be for my liking.
w1ngnut,
I have more jets then I know what to do with and they are both Mikuni's and Dyno Jet....Although I don't know what neddle is in the carb I'll check this weekend, it would be interesting to find out.
Old May 23, 2005 | 10:53 AM
Oldmanracing's Avatar
Their both 63mm long and have the same size on the end that goes into the needle jet/main jet. I am confused!!!!!
Old May 23, 2005 | 11:22 AM
Camds650's Avatar
I used the DJ kit for over a year and had nothing but problems (every combination). I switch back to Mikuni main jet 170 and stock needle and it has never ran so good.
Old May 23, 2005 | 11:48 AM
  #15
The stock throttle slide spring is too stiff to work well with the DJ Kit.
I put a DJ Kit into my sons 2005 and only the bottom to mid was better.
Mid to top fell off.
Put in a lighter spring and now it is great.
The DJ needle is richer in mid and needs more air. Slide needs to open alittle faster.
Even though the 05 spring is the best factory spring todate, it is still too stiff for the DJ Kit.
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Cantbuytime
Aug 17, 2015 06:33 PM
Shooterj2003
Jun 21, 2015 07:51 PM
