Hole Next to Spark Plug
Old Jun 14, 2005 | 02:14 AM
cservnow's Avatar
Default Hole Next to Spark Plug
I was cleaning my 2000 ds650 when I came across a hole right next to the spark plug! It looks like i might have nicked it when changing the plug the last time! It is right next to the spark plug that is on the outside part of the motor. It cranks and runs and does not spit any oil out. It looks kind of deep though. If any one has any input about this it would be greatly appreciated! I have only owned this beast for a month and want to ride it BAD!
Thanks for the help!
Ryan
Old Jun 14, 2005 | 02:16 AM
cservnow's Avatar
This is right on the head where you put the spark plug in!
Old Jun 14, 2005 | 02:38 AM
OregonDunePatrol's Avatar
Is it on the valve cover?
Old Jun 14, 2005 | 02:47 AM
jackass650's Avatar
I have it on mine too its a pin hole
Old Jun 14, 2005 | 02:49 AM
cservnow's Avatar
Yes, It is on the upper most part of the motor. It is the upper most piece of the motor. The top cover! Thanks for your time!
Old Jun 14, 2005 | 02:51 AM
Sandaholic's Avatar
What direction does the hole travel? towards the piston? towards the cam chain? towards the seat?
Are you sure you are not talking about the drain hole that prevents the spark plug holes from filling up with water?
Old Jun 14, 2005 | 02:52 AM
cservnow's Avatar
It might have been a pen hole but now it looks like you could put a screw driver threw it. What is it? A breather hole?
Old Jun 14, 2005 | 03:00 AM
cservnow's Avatar
It goes straight in not down or up but directly toward the center of the motor!
Old Jun 14, 2005 | 05:27 AM
jackass650's Avatar
damn my hole isnt that big
Old Jun 14, 2005 | 09:12 AM
Hightower's Avatar
its a drain hole silly, for the center spark plug pocket to drain out, we all have it. spray something into the center plug pocket, and you'll see it run out the hole you describe. yes, its big enough for a small phillips to fit thru. now what in the world made you think that you possibly could have caused such a hole to appear? [img]i/expressions/face-icon-small-blush.gif[/img]
