Removing Carb
piece of cake.
Disconnect all tubes and hoses and fuel line. Take the little throttle cover off. You may need some needle nose vise-grips for those little,soft screws. Be sure not to loose the little rubber gasket.
Relieve some throttle pressure with your finger and take your needle nose pliers to take out that little brass holder.
Then unscrew the throttle cable and pull carb out from left side.
Hope this helps and that I didn't leave anything out.
Once you get the carb off you'll need a set of small needle nose pliers to remove the factory float cover screws. They will strip if you try to use a screwdriver. Replace the stock screws with a set of stainless hex screws. You will NOT need to remove the carb for future jetting changes.
I found a old thread on the hardware you need to use when changing those bummer stock screws, good luck... 3 - 4X10's 1 - 4X12's (mm)
get those is an SS allen head and you wont strip them again. I got mine at True Value, my local Ace Hardware didnt have the allen head ones.
Originally posted by: LVracer36
Hey, I need instructions removing the carb to put jets, is their pics of doing it, vids etc..
Originally posted by: midnite
If you have a ds650, and want to just change main jets, or adjust the needle, the carb doesn't need to be removed. This makes tuning the ds a dream. The allen head screws are a great upgrade, and time saver.
micheleLeigh
Jul 12, 2015 02:50 AM
