cheap fan fix
cheap fan fix
heres a good and easy fix for the junk fans on the ds, buy a fan for a 2002-2005 honda 954 crotch rocket lots of them on ebay,I got one for $11.00 you will have to sand or turn down the outer lip on the honda fan to get it to fit in the ds schroud one screw will line up with the stock ds mounting location but to secure the other points you can use 2 zip ties the stock heat shield can be used,the honda fan is alot thinner and it should last,after all it is a honda
cheap fan fix
Not really rubber mounts, but the old design where the bolts slide into the fan housing would allway rattle out. I would then try to keep tightening them and I believe the fan just gets pulled apart.
I install a 1/4" pice of flat metal top and bottom and flat bolted my fan to that and no problems since.
