more dyno numbers
#21
Originally posted by: shmee
misterhp do you use a brake on your final #'s???
#22
Originally posted by: crazypainter
XR650warrior, what days are you gonna be there?
#23
Originally posted by: MisterHP
Why would I do that?? Do you ride with your brakes on?
#24
Mine made 64.8 on a local brake dyno, and only 60 on randall and erics. Only difference being complete airbox when I was in ky, and no airbox on the brake dyno. I had guessed around 3-5rwhp by dropping the airbox, and it was right where I figured.
Justin
Justin
#25
also the kit that made 53hp with the lectron, intake and end cap, was 42 on the dyno at little sahara. so some are using the brake and some must not....????....
222
#27
Dyno No,s mean sh*t , take the same bike to the same dyno on different days you get variation in results, then take the same bike to both an inertia dyno on one day and a brake on another and get different results, the other scenario is to put the same bike on two identical dyno,s and get different results.
The fact of the matter is the No,s are only a guideline not a diffinative result, the old saying goes
" When the green flag drops the bullsh*t stops"
Thats my two bobs worth on dyno,s
regards
X-ray
regards
X-ray
#28
Originally posted by: 222
Something wrong with the bike or the dyno or setup? What bike did this?
222
222
