drag racing
Old 07-18-2005 | 09:21 PM
DSengineer's Avatar
Has been here a long time!
Default drag racing
Originally posted by: buhjuh16
Alright thanks alot! How much air pressure should i have in the tires? And as for launching in 2nd would i be better off just reving to a certian rpms and popping the clutch or just taking off normal?
Try bringing your RPM's up to around 5K with the clutch in. Get up on the gas tank like your getting ready to make love to it.
Drop the clutch and pin the throttle when its time to go. If your front end stays down when you launch and you don't have to get off the gas to keep from going over backwards, try 6K RPM's on your next run and so on.
Lowering the front end by backing out the preload on your front shocks helps tremendously in keeping the front end down as well.
Good luck.
Robinhood
12-26-2015 11:28 AM
Todd C Wadas
2) Chassis problems..
09-24-2015 12:31 AM
MikeyBoyesq
09-22-2015 11:02 AM
MikeyBoyesq
09-07-2015 11:44 PM
09-01-2015 02:45 AM
