Ron Woods CDI Wiring. Who knows ????????
Old Aug 18, 2005 | 11:17 PM
Mrneg9's Avatar
Default Ron Woods CDI Wiring. Who knows ????????
Hey guys. I got the wiring from another post. Here it is.
RW-cdi...to...Baja-wiring
red......to...red/violet
white....to...black/yellow
orange...to...white/green
black....to...black
blue.....to...black
green.........not used
The question I have is how do you know which black goes to black and which one to blue. Does it matter ? Also did anyone ever find out where the green wire actually goes or what it is for? Is there any one out there that has purchased the CDI directly from RWR that has an original wiring diagram. Thanks, D
Old Aug 19, 2005 | 12:20 AM
Mrneg9's Avatar
Anyone?
Old Aug 19, 2005 | 02:34 AM
2BIG2BFAST's Avatar
On the baja model it shows both blacks being grounds. red &violet is your 12 volt system the next wire is bk/yl is your trigger coil the next is bk a ground that connects into the wire from the clutch switch then wh/gn is your ignition coils the last one is bk another ground which runs to your run/off switch Hope this helps becouse all it did was confuse me.
Old Aug 19, 2005 | 03:36 PM
Mrneg9's Avatar
Just to let you guys know. Here is what Elliot at RWR had to say.
True, the green wire is not used. It may have been for a tach at one time for the BMW.
Elliott
bigred20653
Oct 2, 2015 10:05 AM
Honski250r
Sep 26, 2015 09:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
