Another 01 to 04 Swingarm question
Old Oct 9, 2005 | 10:59 AM
Entomber's Avatar
Default Another 01 to 04 Swingarm question
I read some past posts but it wasn't totally clear on this topic.
Will on 00 Swingarm Bolt fit an 04 swingarm?
Old Oct 9, 2005 | 11:05 AM
choosetolose04's Avatar
NOPE! That is how I got my lightweight bushings custom made....[img]i/expressions/face-icon-small-happy.gif[/img]
Old Oct 9, 2005 | 11:09 AM
Entomber's Avatar
Ouch... that bolt is rather pricey. Another on to get list.
Old Oct 9, 2005 | 11:16 AM
One thing you have to remember is that you dont only have to be concerned about the swingarm diameter but also the hole that the bolt goes through on the frame. Just a reminder. That is the reason why we decided to go with the custom bushings. Now, I was going from an 01' bolt to an 04 bike. Hope this helps.
Old Oct 9, 2005 | 04:39 PM
Entomber's Avatar
ANyone had any problems? I did put the bolt thru it seems like it clears the bearings but not the bushing. If it's too much hassle I may just stick with the 00 model swing arm. Just wanted to lighten up and make that front end come up a tad easier (on Demand).
Old Oct 10, 2005 | 01:10 AM
JMAC650's Avatar
So what you are saying is you are putting an 04 swingarm on an 00 DS? If that is the case just remove the bearing from the 04 and replace them with the 00 bushings and it will fit. Keep in mind you have to change the caliper mount as well.
Old Oct 10, 2005 | 07:59 PM
Air's Avatar
Air
JMAC650 is correct change the swing arm bushings on the 04 swingarm to the 00 bushings and change the caliper mount and it woll fit.
Old Oct 10, 2005 | 10:40 PM
Entomber's Avatar
Air is that what you did? The Caliper mount from the 00 model will transfer over to the 04?
Old Oct 11, 2005 | 01:05 AM
JMAC650's Avatar
The mount is different. The pin on the swingarm is in a different location on the 04 then on the 00-03. So you must replace it.
Old Feb 1, 2006 | 10:22 AM
jackass650's Avatar
If guy gets the new swinarm and new 05 shocks and am putting it on my 02 with my 02 bolt do I need to do anything with the shock linkage? and if so how much is it and how much is the 04 brake caliper? in other words what exatly will i need to put the 04 swingarm on my 02 bike? and how much will it cost thanks fellas, sorry for the typing i took a couple pain pills
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
