Removing exhaust header bolts
Old Oct 10, 2005 | 04:36 PM
01ds650's Avatar
Default Removing exhaust header bolts
I am going to remove the exhaust header. All the nuts are froze on the studs of course. If I end up just turning the studs out of the heads is that a big deal? Will it go back together again just fine? Also, whats the best/easiest tool to use to get to the two top nuts?
Thanks
Old Oct 10, 2005 | 04:39 PM
DuneMe's Avatar
It's fine if the studs come out.
Small wrench is about the best I can say for the top ones. Tight area for sure.
Old Oct 10, 2005 | 05:03 PM
DaBomb650's Avatar
That's right, just a "click" at a time!
If the studs come out, that's okay, just put them in a vice and and grab them in the middle where there is no threads. Once you get the nuts off, and when you go back togather with the new pipe, put anti-sieze on the studs. This will keep the studs on the head the next time you take them off. Some pipes go on easier without the studs in the way, may be a blessing in disguise.
Old Oct 10, 2005 | 09:23 PM
budtbaar's Avatar
wd40 overnight may help
Bud
Old Oct 11, 2005 | 01:05 AM
NickDS650's Avatar
they are nasty lil suckers! my stock ones kept comin lose so i over tightened them and snapped it, luckily a blow torch and a vise grip got 'er out, but my new ones u move millimeter at a time to tighten and losen and i take my time cause bustin em and/or stripping them is a hell of a project, time well spent i say
zach1106
Jul 31, 2015 01:55 AM
Bell21
Jul 28, 2015 06:52 AM
bpegram84
Jul 22, 2015 08:15 AM
Shifts
Jul 3, 2015 07:59 AM
