Help with winch location?
Old Dec 12, 2005 | 12:00 AM
alwaysride's Avatar
Default Help with winch location?
My buddy wants to buy a cheap winch. I was thinking since he has an aftermarket bumber from brp, would it be possible to mount a small winch to it somhow on his 04 outlander 400. This bumber is from brp but not the one you get on the ext versoin.
Old Dec 12, 2005 | 12:52 AM
R00ST's Avatar
You are trying to mount it to the actual bumper? Why not just mount it with a frame mount kit (usually warn or moose etc have the mount kits for just about any quad) then if needed put a roller fairlead on the bumper so it does rip it up.
I used to like my superwinch t1500 I had on my beartracker (LONG time ago) but that machine didnt weigh much. I would say he could get buy with a superwinch 2500 or look for a cheap moose winch (warn tends to be pricey but are nice).
Been a long time since ive talked about winches!
Old Dec 12, 2005 | 01:15 PM
alwaysride's Avatar
More than likely we will get a mounting plate but i was just curious
Old Dec 12, 2005 | 02:08 PM
lilnotts's Avatar
my bro is puttin a superwinch on his gf outty 400, and he bought the winch brackets and roller fairlead from brp, this machine also has the std steel bumper from brp(not the XT bumper), the roller fairlead bolts rite up which is nice, but everything else so far has to b modified somewat to fit/work rite, the winch bracket is made for a warn winch, superwinch doesn't fit so he had to make a plate to add to the winch bracket to make it work, the switch mount had to also b custom, not sure bout other winch mount kits, but if ur buyin a brp kit, do urself a favour n buy a warn winch, make things so much easier
Old Dec 14, 2005 | 10:46 PM
phred's Avatar
You may or may not like it but I moved my winch on my 400 Outty to the bumper. 2.5 Warn that it came with and the bracket practicaly lined up perfect. if you can weld or have a buddy that can its simple. Take a look at my picture. It's now out of the crap I just have to hook up higher on trees if I have to and it's now easier with the plow.
Old Dec 15, 2005 | 02:51 AM
RIDER11X's Avatar
Check out Montana Jack's reciever system, that may work for him and allows the winch to go front and back.
Old Dec 16, 2005 | 11:32 AM
2BIG2BFAST's Avatar
mount it to the front of choose2loses bike becouse after i bury him in all that sand he is gonna need some help out.
Old Jan 10, 2006 | 04:19 PM
Woodysbng's Avatar
Glad I joined this forum, I had just ordered the winch kit from brp and I have a superwinch. I just called and modified my order.
Johnny Mac
Aug 15, 2019 03:13 PM
EIF
Apr 20, 2017 07:15 PM
Oct 10, 2015 10:20 AM
Lucas Bohanan
Sep 29, 2015 01:16 AM
cboler9
Sep 24, 2015 08:35 PM
