TM45 jetting Glamis
Old Jan 1, 2006 | 03:28 PM
ERBEDS650's Avatar
Default TM45 jetting Glamis
Say what are the TM 45 jetting specs for a Big Gun Pipe, K&N, open air lid, glamis riding, I have a 145 main in it now, AM I too lean???
but im getting some Back Fire on the top end. starts right up. idle great!
Old Jan 1, 2006 | 08:42 PM
eRo's Avatar
eRo
i would say try a larger main. 145 seems lean, u got a pipe that flows alot on top end. u got extra main jets? i know my ds likes the main richer than 145. needle clip about middle slot or higher.
Old Jan 2, 2006 | 09:53 AM
Hightower's Avatar
145 is way lean for open airbox at sea level, lose the lid and the gasket under it and also the two snorkels, go up a size at a time and notice the gains, keep going up until you get no more gain, run a buddy you are close to up the longest climb glamis has each time you change and you will see the gains. my guess is you'll end up closer to 160. being that lean, you may have been faster with the stock carb.
Old Jan 3, 2006 | 10:39 AM
SCOUNDREL's Avatar
I believe I run a 167.5 at Glamis.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
