DS 650 oil pressure light
Old Jan 2, 2006 | 06:47 PM
JMAC650's Avatar
Default DS 650 oil pressure light
If you have an 03 you shouldn't have to bleed it. Just try the sensor first and that should take care of it.
Old Jan 2, 2006 | 11:49 PM
AusyATVdude's Avatar
Thanks JMAC650 I have ordered them from my Bomber dealer and will just try the replacement sensor first. It will be good if I do not have to bleed it every time I service it. I must admit I have done several oil and filter changes without bleeding before. I assumed that since the oil tank is mounted quite high compared with the oil pump and filter etc that it would self prime as you suggest.
Old Jan 2, 2006 | 11:54 PM
DSWOLF's Avatar
i have the 2000 model and i have to prime it but i do think that they changed that for the newer models.
Old Jan 3, 2006 | 12:07 AM
Thanks DS Wolf. I am not sure but will try and get away without bleeding if its possible. Will see how it goes.
Old Jul 14, 2018 | 10:57 AM
  #15
Bombardierds650's Avatar
Default Flickering oil light
Hey there I have a 2000 ds 650 racer and I have replaced fan,thermostat new hoses and flushed my radiator and when the bike gets warm my light flickers when I come to a stop only if I take off it goes out,thinking the sensor but wondering if it could be something else?Any suggestions?
Steeldon
Sep 9, 2015 09:38 AM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
