TM45 vs Lectron 46 vs KMS EFI
I think I will give Kelly a call and get an update on progress. I would like to be able to run either fuel whenever I want. The o2 sensor problem is about the only thing holdiing me up on it. I want to live in a EFI world also[img]i/expressions/face-icon-small-happy.gif[/img]
I must say that Kelly from KMS has been great to work with. On the phone he seems to love to talk, I feel bad wasting his time on the phone when he talks for 1/2 hour when I only had a 2 min question! I have been running the EFI since the end of 2004. Started out with more primitive ECU that used a narrow band O2 sensor and it required user input. When through a few upgrades to get where I am now with a wide band O2 sensor and I have absolutely zero user input on my behalf. I am sure my engines demands are some what mellow compared to the turbo alky engines.
I have no experience with running alky, I do know that the fuel requirements increase so much that a whole another fuel circuit is required, including another injector. As a dune rider, alky doesn't make sense for me as fuel mileage is somewhat of a concern.
Leaded race fuel and wide band O2 sensors do not mix. At DS days I lost an O2 sensor. The engine would not run at all and had to be towed back to camp. Kelly was there and checked out the EFI, put in a new O2 sensor free of charge and is been running great since. It could of been a faulty O2 sensor or the lead contaminated the O2 sensor, will never really know the true cause of the O2 failure. I only have about 10 gallons of fuel through the new O2 sensor, but so far no problems. Ideally if I were to do it again, I would run a lower CR so I could run pump gas. I did find that my race fuel supplier (F&L fuel) has a 105 octane unleaded that is rated for 14:1 engines, mine is only 13:1. I have to do some more research on it before I dump it in my tank.
If I understand it correctly, all nitrous does is add more O2 to the mixture. With the added O2 it requires more fuel to be added to get the idea A/F ratio. So basically nitrous allows you to run more fuel in the same space and maintain the ideal A/F ratio. (Please correct me if my explanation is incorrect) With the EFI, Kelly is adding nitrous only (dry shot), the EFI senses a lean condition and compensates with more fuel. Boondocker works with float bowl pressure on quads, although I did see that they have EFI system for snowmobile applications. I am sure ODP can give us more info on that.
Do you NEED the airbox, or...?[/quote]
Yes i need the airbox so im wondering if both the tm45 and the lectron 46 would run alright with the airbox and the lid removed.....i need the airbox due to all the mud, water etc in my riding area. I no the tm45 uses the stock carb boots but does the lectron fit into the stock boots or does it take some sanding down of the rubber boots to make them a bit bigger?
#16
So, in review, if your specific turbo needs to be controlled by a specific 02 sensor, you may be required to run with a sensor that is not lead tollerant. However, lets not confuse the issue that all 02 sensors cant be used to tune quads with leaded fuels, because they actually can tune quads with leaded fuels. Talk to your builder about what your options are, or if you build your own, do some research and find out what works best with your application.
#17
I also wanted to add that Engine tuning is huge. Now I know that you old timers know how important it is. When specs get tight, like with Nitrous, Turbo and Superchargers, people have to know what thier air/fuel ratio really is. For those whose specs are not that tight, but want the most HP possible, the correct air/fuel ratio is right about 14.7:1. That means 14.7 parts of oxygen to 1 part of fuel; slightly higher numbers (leaner) or lower numbers (richer). By tuning, you will get the absolute correct ratio that makes the most horsepower at what ever RPM range you test at. As I have mentioned before, at this ratio, theoretically, all available oxygen in the air combines with all available fuel. This ratio is called the stoichiometric ratio and the value is 14.7 (it takes 14.7 parts of air to combine with 1 part of gasoline.).
Now a guy could hunt and peck all day long and find what ratio is best by the feel of the quad. He can also go to a dyno and test assuming he tests at a facility that check the air/fuel ratio. But, if you travel to higher elevations, the whole thing will be off again. There is nothing like having real time information available to you to make those decisions, especially for those quads that have no EFI, or EFI that is not automatically controlled, or quads that have carbs.
#19
#20
Originally posted by: OregonDunePatrol
Think of it as a tuning session every time you ride. Also, think about the engine damage you might have when you run too lean. Still think its pricey? - dude, that sucker is cheap!
