NEED HP
Old Jan 8, 2006 | 08:43 PM
crazyds's Avatar
Default NEED HP
IM GETTING INTO 300FT DIRT DRAGS I NEED SOME INFO.HAVE PIPE JET KIT CDI BOX CLUTCH KIT 15 TOOTH FRONT 22" REAR TIRES. I WAS WONDERING WHAT ELSE I COULD DO TO GAIN HP. IM LOOKING FOR A BIGGER CARB. I WANT TO STAY RUNNING 92 FOR GAS ANY INFO WILL HELP THANX
Old Jan 8, 2006 | 09:40 PM
1BigDSRider's Avatar
Default NEED HP
I am running a Hpr Hv 46. Its a great carb and should add good hp to your bike. Also Im running 87 octane. So it helps at the pump price wise.
Old Jan 9, 2006 | 01:09 AM
quadbart's Avatar
Default NEED HP
Hey Crazy.
Where you plan on racing at?
I see your from LG Wisc. Im 'bout 1/2 hr south of you just across the Il border.
Check out this site. ATV TrailMasters Theres a few people on that site in your area that drag also. Check out their forums.
Old Jan 9, 2006 | 01:24 AM
Hightower's Avatar
Default NEED HP
92 octane fine for 11.5:1 compression, I've been running it for several years.
Old Jan 9, 2006 | 03:01 AM
DSNUT's Avatar
Default NEED HP
Hightower is right. If you are running an aftermarket cdi that offers additional timing advance, you really shouldn't exceed 11.5:1 compression on 92 octane. I have run that for years as well with no problems but it has to be getting close to the limit if the recommendation is to run a 50/50 mix of premium and racegas at 12:1.
Ron
Old Jan 9, 2006 | 11:06 AM
thebigshow's Avatar
Default NEED HP
if u are wanting to improve your 300 time, a bigger carb will proberly your best bet. you defently want to start with a good foundation, a good carb and a good pipe..then it NEVER stops...
Old Jan 9, 2006 | 12:58 PM
crazyds's Avatar
Default NEED HP
quadbart,
i race in janesville wis monkey butt polo il ,this year im going up to burr oak , eau claire my uncle bought andys 400 polaris andy is the guy that does wisconsinatv.com
