hrp vs. ron woods vs. turbo kit
now simple question....what is the kit to go with for the dunes...with a rider that like to ride the trails as well as do some light drags...basically an all around dune machine with *****.....all on pump gas i might add..not sure if the turbo will run on pump gas....so it may be out.......ok so thats my question lets here the opinions??
IMHO rwr stuff is outdated... Sure you could run a stage III (dont even know what that runs these days) but I think you would be MUCH happier with the 730 kit, a lectron 48 (or EFI) and doing some other small stuff to the engine.
The nice thing about the turbo is that as far as I know it does run on pump gas, you can run it on an all stock engine and still be putting down 70-75 hp. EFI comes with the turbo so if tuning is something you dislike that would be an added benefit (but then again if you like tuning their are endless possibilties to playing with the fuel maps)
If it was my money and I spent most of my time in desert/trails/dunes I would put the turbo on. Second choice would be a 730 build up.
the tubos are cool... some people i have talked to said if you have a turbo you should have a spare bike.. I have a Ron Woods stage 1 with port/polish,big valves, cams & piston... runs on pump gas( i use 50/50 pump & vp for the cooling) and i'm at 61.20 hp on the dyno. the motor work was $1700. stage 1 about $1400 total: $3100 almost $2000 less than the turbo. super reliable.. does the trail rides @ 10mph with the kids.
first i know its stock suspension...but still the plushest ride of all the models...so not worried about the suspension part....second the money is no object is getting lost on the functionality of the machine...its suposed to bea all around dune machine with the abilty to open a can at the same time....not just a quad killer.....so far only one has really praised the ron woods...is imho the mr hp or that a differnt company?
