Hi Everyone
Old Feb 28, 2006 | 06:39 PM
R00ST's Avatar
Default Hi Everyone
I think others probably went the honda route as they are widely available and are now known to work properly. I would definitley give the DS throttle a try though. Dont see why it wouldnt work as long as you could get the cable setup properly.
Old Mar 1, 2006 | 12:45 AM
BigWaynester's Avatar
Default Hi Everyone
You can use the same cable with the honda, it bolts right up, I'm not sure if the DS will bolt right up.
I would just try the spring mod 1st and you might be happy, if not then get a different throttle.
spring mod.
I could not find what I was looking for, only use this to see how the spring comes out. DO not cut the spring!
