repacement battery?
Old Mar 7, 2006 | 10:57 PM
SANDMAN430's Avatar
Default repacement battery?
what is the replacement battery of choice? i've heard of the 450 yzf battery and the weight is good but do they hold up, my stock battery is 11 pounds. wow[img]i/expressions/face-icon-small-blush.gif[/img]
Old Mar 8, 2006 | 12:17 AM
flyinds's Avatar
sandman can not talk about the yfz battery. i have a odyssey pc545 gell battery and i believe it weighs in about 12lbs. i am really impressed with the battery. you can find on ebay just tpye in pc545 in the search. just my 2 cents.
Old Mar 8, 2006 | 03:36 AM
Scatterbrain's Avatar
I would also like to know what the smallest lightest battery that will work is?
Old Mar 8, 2006 | 04:10 AM
XR650Warrior's Avatar
the pc545 is the battery of choice for durability and long life, saving a few lbs. on the battery will not help you if it does not perform.
Old Mar 8, 2006 | 09:39 AM
choosetolose04's Avatar
The yfz battery is small and will do the trick...and it is light. Although I did not opt to run this battery simply to play it on the safe side while running NOS. You should be ok. I know some of the top fuel DS dragsters who are running them, [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Mar 8, 2006 | 11:00 AM
SANDMAN430's Avatar
any non racers run the yzf battery? and what kind of luck have you had, i have been checking other sources and i guess they need to be on a battery tender all the time or they will fade quick. thanks for any help
pgamboa
Dec 24, 2023 11:52 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
