ds caught on fire
Old Apr 4, 2006 | 01:20 AM
DSengineer's Avatar
Has been here a long time!
Default ds caught on fire
I'm having some bad flashbacks to a campfire incident I once had involving a 5gal fuel jug.
Old Apr 4, 2006 | 02:04 AM
BlackHawk's Avatar
If you had a fire ext. mounted to your ATV that was burning I'm not so sure it would have helped you. However if you had an ABC fire extinguisher mounted in your garage you could put out a burning ATV, or anything else that could catch on fire. Mount a Fire Ext. in your garage and keep it charged and you'll be safe. Not to mention once you are prepared for something like that it will likely never happen which is great in and of itself.
Old Apr 4, 2006 | 02:52 AM
pugads650's Avatar
it probably wouldnt look right either im going to double check everthing tommorow to make sure it is safe to use thanks again for the comments and help
john
Old Apr 5, 2006 | 01:29 AM
pugads650's Avatar
funny how something as small as sealer can cause this much trouble also what is the safest possible jetting setting i can run with my bike i dont need it set up for max performance just for reliability i have a hmf pipe and a 175 jet stock was 165 i think when i go riding i go to gorman atv park in california thanks again for the help and the comments
jonathan
Old Apr 5, 2006 | 01:42 AM
  #15
Sparky8370's Avatar
definetely change that oil dude. Then, change it again after your first good ride. You don't want to have your oil thinned out from the gas to be what's lubricating your motor, never mind that too much oil can start blowing out seals. Better safe than sorry.
Old Apr 5, 2006 | 01:49 AM
  #16
pugads650's Avatar
will do wich oil do you sugest im probaly going to do this tommorow
Old Apr 5, 2006 | 01:57 AM
  #17
Sparky8370's Avatar
Well, I'm not a ds guy. Don't know what they're running, or what you got in there now. If it's petro based, then maybe a semi-syn for the first and then a full syn from that point on.
Old Apr 5, 2006 | 01:59 AM
  #18
Sparky8370's Avatar
From what I hear, BRP XPS 2 stroke (full syn) is the best for my sled, so it sounds like BRP has their chit together as far as oil so maybe go with them.
Old Apr 5, 2006 | 02:08 AM
  #19
DSNUT's Avatar
Great advice Sparky! [img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 5, 2006 | 10:56 PM
  #20
pugads650's Avatar
is that bad that i got gas in the oil when the motor wouldnt turn over i hit the starter button a couple times before i took out the spark plug could that have caused and internal damage to the motor
