DS rules Planet Sand...
Old Apr 14, 2006 | 10:59 AM
  #31
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
Default DS rules Planet Sand...
Eric,
Are you using only one spark plug to control high rpm burn?
OMR
Old Apr 14, 2006 | 11:06 AM
  #32
OregonDunePatrol's Avatar
Originally posted by: AZSAND
Gee Golly Mr Marky hope 14-1 is okay [img]i/expressions/face-icon-small-happy.gif[/img]
[img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 14, 2006 | 11:34 AM
  #33
ScoobyDFW's Avatar
why do you think a 180HP motor is slow reving??????
your fast reving 855 is capable of 180HP.
a stock frame DS is capable of 4.0 sec +- in 300 feet.
there was a 450 based bike that ran 4.0 at planet sand.
the <u>SLOPE of the HP curve</u> is a factor in acceleration.
http://media.putfile.com/hear_the_turbo_DS
Old Apr 14, 2006 | 11:57 AM
  #34
choosetolose04's Avatar
Scooby, when are you gonna step up to the plate and show up just how much power these Rotax motors are absolutely capable of pushing?
Old Apr 14, 2006 | 12:11 PM
  #35
ScoobyDFW's Avatar
I've been doing that for years. I have never been out powered by a stock frame single cylinder quad anywhere I've brought my DS to date - I have lost a couple times for any number of reasons. I stopped running all over the country, no need to do that. Last time out I beat a HPR 730cc that was running a turbo and alcohol.
Old Apr 14, 2006 | 12:12 PM
  #36
MrHorsepower's Avatar
Pro Rider - Oldham Racing
BUILDS THE FASTEST DS's ON THE PLANET!
Want a hot DS, or maybe one of the fastest DS's on the planet? This is the man to contact!
Scooby you said 180hp cant be obtained with 16:1. Lower compression dont rev as quick as high compression.
The 450 based bike ran one 4.08 the rest were teens and twentys and the pilot was 70lbs. I weigh 170lbs lets put a 70lb pilot my bike and it will go 3.60-3.70 range. Not to mention his bike is probably 30lbs lighter than mine.
Old Apr 14, 2006 | 12:13 PM
  #37
That still doesnt answer even the very question that you have made known...a DS capable of handling 180hp...now when are you going to step up to the plate and not only push the envelope to your claim of 180hp but to also show up to some of these premier events that are being put on now days and see where you stack up against the drag bikes....not the dune bikes that run around Little Sahara with pipes and jets? [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Apr 14, 2006 | 12:19 PM
  #38
ScoobyDFW's Avatar
Ah choose, wait a minute here, do I even have a drag bike????? No I don't. My DS is a 100% stock frame dune bike. I go the LS to ride the dunes and play around.
I'm not building a 180HP bike. I simply stated that with 855cc it could be done.
  #39
1BigDSRider's Avatar
Originally posted by: Hightower
two questions,
Why doesn't Planet Sand post the fastest single cyl 4-stroke record on their records page - I personally think they should
and what kind of motor holds their fastest single cyl record of 3.94, anybody know what the details are?
Sherry, Said that they would be adding another class to the records (4 Stroke single cylinder). But she needs all the required info to post them. Eric needs to submit his info and so does Glenn, and Jeff.
Old Apr 14, 2006 | 12:23 PM
  #40
ScoobyDFW's Avatar
100 lbs doesn't gain 4 tenths, but yes your bike could do 3.6 in the future.
with the lower compression you run much higher NOS and launch with the NOS, the more NOS the faster the reving.
