ds650
Old Apr 30, 2006 | 11:22 PM
fxrider9382's Avatar
Default ds650
on my ds i keep hearing a popping noice and it seems like its coming from around the chain area. i just bought the bike brand new. Anyone no what it might be. thanks
Old May 1, 2006 | 01:48 AM
monkeyinajar's Avatar
Default ds650
Chain tension, chain guard, if it is in fact that locale. Also, check the chain rollers.
Old May 1, 2006 | 01:51 AM
DuneRider650's Avatar
I ride a little here and there......
Default ds650
Do you mean a clanking clickidy click sound when in high gear at low low speeds? Thats what mine did before i opened the engine up a little. I think it was the chain slapping on the guard on the swingarm....but if that isnt what you are hearing like monkeyinajar says check the roller chain tension etc.
Old May 1, 2006 | 10:28 AM
Default ds650
it happens when im goin over bumps and off camber stuff, theres nothing loose, so i guess it probably is the chain slapping against the guard, do you think its something i should really worry about
Old May 1, 2006 | 01:41 PM
GITRDUN's Avatar
Default ds650
Not trying to steal your thread, but while on the subject. Just how do you adjust the chain tension on a 2001 DS? Mine is terribly loose and i didnt see any obvious way to adjust it when i looked at it yesterday. Dont have the manual or any info on it.
Old May 1, 2006 | 02:16 PM
Default ds650
Loosen all 4 bolts on the bottom of the swingarm....then you should have a tool like a small piece of rod that came with your tool kit...that will now slide in a hole on the rear sprocket hub and then in the side of the swingarm...You then pull back the quad to tighten the chain or push it forward to loosen...after its adjusted tighten up all the bolts and you should be good. It does tell you a more talked through method in the manual but thats basically it.
As for the sound fxrider...if its the sound im thinking of no you dont have to be worried mines done it for 2 years now.
Old May 1, 2006 | 08:24 PM
FatHolly's Avatar
Default ds650
Check your ride height... if you are too low your chain will hit the roller every time you hit a bump. It may feel better to have it lower due the poor stock steering geometry, but you may be too low... I was too low and ate up two chain rollers in one day, before I figured it out, and raised her up . You should have 4-6 ninches of sag from fully extended in the rear.
Old May 1, 2006 | 09:09 PM
Default ds650
alright ill check that out thanks everyone
Old May 2, 2006 | 02:16 AM
Default ds650
Yup, I had that sound a long time ago and replaced the chain roller. And also, when adjusting your chain, if you don't have the stock tool, you can use an allen wrench, screw driver, etc. They'll all work
Old May 2, 2006 | 04:25 PM
Default ds650
how much are new chain tensioners, and it only happens when im goin over bumps or turning, it seems like its in the axle but im gettin sick of hearing it
