Check it Outi
Old May 9, 2006 | 03:23 PM
chirochris's Avatar
Default Check it Outi
are they the same size front and back?
i was looking at 26x11x12 rear and 26x9x12 fronts..mudlite radials(xtr) i think
any idea of the true weight difference
Old May 9, 2006 | 03:47 PM
Poindexter660r's Avatar
They have the specs on the tires at ITP's website. The difference between the 26-11-r12 XTR and the 26-12-12 Mudlite is 5 lbs. each. It shouldn't be a problem for your 800.
Old May 9, 2006 | 06:49 PM
chirochris's Avatar
whats the difference in weight from the stock
Old May 9, 2006 | 07:57 PM
05dsrider's Avatar
i know itps a great brand and all but before you go off and buy a set look at http://www.completewheelsource.com/2007/atv.html their called motorsport alloy wheels and i think they look alot better than the itp
Old May 13, 2006 | 01:41 PM
  #15
cbi1000's Avatar
So you haven't noticed any difference in the visco loc system. I heard bigger tires really makes a mess of that system.
Old May 14, 2006 | 01:02 PM
  #16
The visco lok is a simple mechanical system. As long as both front tires are the same size, it works fine.
The weight difference between stock and the c7's with the mudlites is at least 5 lbs. per corner. The stock stuff is feather weight. If you go to XTR's your at about 10 lbs. per corner. Not a problem for the 800 or even the 650, but for the 400 it will kill it.
slowgsxr97
Mar 18, 2022 03:40 AM
COFatboy
May 2, 2020 12:06 AM
Blueholleroffroadpark
Where to Ride
Jul 30, 2015 05:39 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
