rw stage 3 cams
Old 05-09-2006 | 08:57 PM
rfwlll's Avatar
Default rw stage 3 cams
Hey guys I was just interested in knowing what profile cams come in a ron woods stage 3 kits? Thanks, RUSS
Old 05-09-2006 | 11:45 PM
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
A1 in is .433 with 268 dur
A2 ex is .406 with 278 dur
#7 is .450 with 294 in/ex
#9 is .425 with 260in/ex
You can get any of the pick.
Old 05-10-2006 | 03:06 AM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
NOW THATS SERVICE......[img]i/expressions/face-icon-small-happy.gif[/img]
Old 05-10-2006 | 11:31 AM
DragonDJ11's Avatar
Ok, what is good about one over the other. Is one better for this application, and another for that???
Old 05-10-2006 | 12:00 PM
THEBOM's Avatar
[/quote]
Ok, what is good about one over the other. Is one better for this application, and another for that???[/quote]
That correct!!! Low ,mid, and high rpm power.
Old 05-10-2006 | 12:39 PM
ERBEDS650's Avatar
Whats the main difference between the A1 A2 and the Web 109s? Im still looking for the best midrange cam
Old 05-10-2006 | 01:00 PM
strictlysand's Avatar
I ran the race 7's for about a year and half and had a vavle spring failure, which resulted in about a $3,000 repair (new head, head work, new piston, cylinder, cams etc.) I was going to run the 7's again but decided to go with a less aggressive cam (A1/A2). If you go with the 7's just keep in mind that they love the high rpm's, at least that was what I experienced. I made my first run with the A1/A2 cams and noticed a nice and steady power all the way through the power band. If you do go with the 7's you also want to make sure you change those valve springs more often or you could have a problem like I did.
Old 05-10-2006 | 01:30 PM
DSNUT's Avatar
Why can't you have a cam set that gives you great power from bottom to top?
Old 05-10-2006 | 01:52 PM
Goodsound's Avatar
Set a New OEM chassis 4 stroke national record on his OMW DS855 - 3.93 !
It would be nice if every company gave thier cam specs so willingly.
Old 05-10-2006 | 02:42 PM
amd's Avatar
amd
Goodsound I couldn't agree more!!!!!
