installed lightend fly wheel wont start
Old May 19, 2006 | 11:37 PM
QUICKSAND04's Avatar
Default installed lightend fly wheel wont start
installed lightend fly wheel spin starter gears doesn't spin crank
any help will be greatly appreciated
thank you
Old May 20, 2006 | 12:25 AM
crazypainter's Avatar
Is the oneway in backwards? The arrows should go opposite directions from the flywheel to the sprag.
Old May 20, 2006 | 01:26 AM
Crazypainter thanks for the thanks for the responce
do not know what the one way is?
please explain
thank you!!!
Old May 20, 2006 | 09:54 AM
Majorecho's Avatar
could also be that you installed the thin flat washer on the wrong shaft and when you tighten the case back up it bound up the gear. If you loosen the case bolts a full turn out each and then hit the starter button with the ignition off and the motor turns over than that is your issue. If not pull the flywheel off and check your sprag clutch.
Old May 20, 2006 | 09:55 AM
Its the piece that goes in the end of the flywheel that goes against the crank and has the gear that goes against the intermediate gear that meshes up to the starter. The picture in the repair manual shows that the arrows go the same direction but thats wrong if you do your one way spins freely and doesn't grab the crank to spin it.
Old May 20, 2006 | 01:27 PM
DSJOBBER's Avatar
I did that same damn thing when I pulled the cover off to polish it. Was confused as hell until I decided to start trying things. That little thin washer sure does an important job.
Old May 21, 2006 | 12:25 PM
650VIPER's Avatar
Just so you all know. The sprag was put in the wrong direction. We pulled it apart at the dunes, and scratched our heads for a while as the manual shows it backwards, then we did some thinking and put it in and she worked. Nice call Crazy.
Old May 21, 2006 | 06:18 PM
[img]i/expressions/face-icon-small-smile.gif[/img]
MikeyBoyesq
Nov 27, 2020 02:44 PM
volsgo30
Jun 4, 2015 06:07 PM
Dieseltrash
Jun 1, 2015 06:53 AM
1000gade
May 27, 2015 12:37 PM
