quick question...thank you
I am not sure but I do know that my husbands DS wouldn't run if the battery was dead or unhooked. Unless he jumped it and it would run for a little bit and then die again. And that was when the crappy cheap CDI killed his rectifier. It could be something else. I will try unhooking his battery tomorrow while it is running and see if it still runs with everything working right.
Wish I could help you more.
havent done the subframe ground yet.....doing it tonight or tomorrow..
had a big ride planned already and the outy 800 blew the water pump gasket and is back ordered....so i need to ride the DS....
we will see....thank you
im leaving now for the ride let you know how it goes
