520 chain gains
Old Jul 16, 2006 | 07:44 PM
rcoop's Avatar
Default 520 chain gains
Originally posted by: duneittilludie
The aluminum axle sounds interesting but i am saving now for a Nitrous system so maybe some day?If i can gain just a few quad lengths i will be very pleased with my stock bore.Actually the aluminum axle would probably add a few lengths itself.You guys are a bad influence.LOL.
run a titanium axle it will give you the more stealth look[img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 16, 2006 | 11:18 PM
duneittilludie's Avatar
Scooby i got the chain from RMATV and the sprockets from ON DUNES.I switched back to my stock front tires from the 23" that i was using Saturday and the front end coming up problem was not quite as bad.My DS really shoots out of the hole now.I am even beating some of the 120-130 lb youngsters on yfzs out of the hole and in most cases up the hill.
Old Jul 16, 2006 | 11:21 PM
lilnotts's Avatar
how much abuse can these aluminum axles withstand?
Old Jul 17, 2006 | 01:16 AM
FatHolly's Avatar
Which of the big boys are running the 520 on a duner? Can you get a 520 that is as strong or stronger than the 530?
Old Jul 17, 2006 | 01:26 AM
  #15
FatHolly if you mean big boys in terms of physical size i kind of qualify at 230-235 lbs.If you mean big bore motors i cant answer that.I have only two dune rides on my 520 chain and sprockets and i ride the dunes pretty hard at times and i put the 520 through the paces this wekend without any problems.The tensile strength rating on my D.I.D 520 ERT2 chain is 8400 which should be plenty strong.
Old Jul 17, 2006 | 11:44 AM
  #16
choosetolose04's Avatar
I pounded my 26" Gun-Drilled aluminum axle through some of the hardest whoops there is even when my bike was a full stock chassis and its still going strong. They are pretty durable, believe it or not. For the bigger boys on the bigger toys, I would recommend the 34" solid "play" aluminum axle just to be on the safe side. We dont want them bigguns getting hurt, [img]i/expressions/face-icon-small-happy.gif[/img]
Holly, I've seen some fairly healthy people run these 520's without a problem. Just think about a 180hp banshee with a 300lb rider onboard, [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jul 17, 2006 | 03:15 PM
  #17
rfwlll's Avatar
Originally posted by: rfwlll
Hey speaking of axles. Has anyone ever tried a predator or banshee axle for comparisons. I know those axles are also setup for tapered bearings and are much smaller, well at least the banshee axle is alot smaller. Anyone compare yet to see if they would work, I know my predator axle is a little smaller and narrower.
[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jul 17, 2006 | 03:31 PM
  #18
ERBEDS650's Avatar
Holly, I ve been running a 520 chain on my LT500 for 18 years, No Problems!!! Im just havent been ready to do so on the DS yet, its kinda like it works so why change it tude.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bmark0610
Sep 7, 2015 09:42 PM
