engines mods
Old Jul 31, 2006 | 12:32 AM
BAJAxFANATIC's Avatar
Default engines mods
Im going to be repairing the engine in my 04 baja x. I was wondering if i put an oversized cam in is there anything else i need to do to the engine.
Old Jul 31, 2006 | 01:20 AM
650VIPER's Avatar
If you do just cams, you need to make sure you have enough valve clearance. You might not clear the stock piston. I would guess to say if you stay with a mild cam, you will be fine. Make sure you do something with your valve springs though. Depending on the cam choice, you will either need dual rates, or shim unders. And of course if I was in there, I would just bump the compression while your at it. Both of them together makes for a nice little combo.
Cole Hadden
Jun 15, 2025 09:05 AM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Jul 22, 2015 05:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
