Temp guage
Old Jul 31, 2006 | 01:52 AM
Steveo10's Avatar
Default Temp guage
I search for this problem, but ill cut straight to the chase... I have had the temp light come on a while back. So i took the DS in to get looked at. The mechanic said the fan wasnt workin and i got it replaced. Today i was ridin and light would come on for a minute and then shut-off. The oil/coolent resevoir looked good. A guy was also ridin a DS in our group and he said it is probably just the senor screwed up? Anyone also had this prob?
Old Jul 31, 2006 | 02:15 AM
2BIG2BFAST's Avatar
Default Temp guage
throw you a 69 dollar esr inline water temp guage so you can visually see how hot its getting. there cheap plus they look cool. you could also wire the fan wires together with a toggal switch and turn it on and off manually
Old Jul 31, 2006 | 02:22 AM
Steveo10's Avatar
Default Temp guage
Water temp/oil pressure guage would be handy to have... sometimez i wonder was is happening inside?
Old Jul 31, 2006 | 12:21 PM
SW2steve77's Avatar
Default Temp guage
Steveo10, take a look at my setup. It was very inexpensive to make if you know someone that does some machining. The guages I got from autozone for 30 some odd dollars and the aluminum piece that is between the radiator and thermostat was made. It helped me out at silver lake this weekend when I keep running hot and the fan was messing with me big time. hope this helps.
Old Jul 31, 2006 | 12:25 PM
xFreebirdx's Avatar
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Veteran: Army
Loved
Community Favorite
Default Temp guage
Nice, very clean looking also. =]
Old Jul 31, 2006 | 12:41 PM
SW2steve77's Avatar
Default Temp guage
Thanks......I saw the same setup when I was doing a search and they want 89 dollars for just the temp guage and that aluminum piece.
Old Jul 31, 2006 | 07:57 PM
mudnuri's Avatar
Default Temp guage
I got one from JTATV. com
It was easy and mounts right up with two hose clamps. The one I got was lit and mounted right next to the tach.
Old Jul 31, 2006 | 07:59 PM
bombrider04's Avatar
Default Temp guage
I wired my ds direct becuase on the early model ds650's they had problems with the swith but I also have it so the fan will come on by itself...my ds650 seems to run really hot becuase I am using reg car antifreeze but a few days ago the guys were recommending engine ice which can be bought at rocky mountain for about 12 bucks or so...it cools it by about 50 degrees better then reg coolant and isn;t toxic like antifreeze.
Old Jul 31, 2006 | 08:26 PM
ERBEDS650's Avatar
Default Temp guage
For water temp gauge, couldnt you use teh same sensor as the one in the thermostat?
Old Jul 31, 2006 | 09:08 PM
VEGAS650's Avatar
Default Temp guage
I still have a liguid filled Autometer gauge (for vibration) and the aluminum piece for the sensor.
I've been tripping over them in my garage.
