nos setup ?'s
Old Aug 22, 2006 | 06:24 PM
  #101
choosetolose04's Avatar
Default nos setup ?'s
Originally posted by: OregonDunePatrol
Me too. Im going to leave this thread alone for a while so my brain can recover! lol -
You need to come on over to the Picture Rebuttal thread....its interesting reading.....to say the least. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Aug 22, 2006 | 06:26 PM
  #102
OregonDunePatrol's Avatar
Old Aug 22, 2006 | 06:51 PM
  #103
drakester's Avatar
I will have to said that this has been one of the most informational threads that has been on here in a while. It has been very good reading. This is the stuff I like to see. A bunch of members with very good information and explaning each information like men. In my opinion also if all these system are set up and tuned correctly they all are good systems.
Old Aug 22, 2006 | 08:50 PM
  #104
Old Aug 22, 2006 | 09:00 PM
  #105
650VIPER's Avatar
Harbor Frieght has them thermometers for 27 bucks. I will swing in tomorrow and pick one up.
So your saying Marky, that I need to redo my install to put in the 40 hp shot?
Old Aug 22, 2006 | 09:03 PM
  #106
Didnt BOSS send you a T right off the regulator?
Old Aug 22, 2006 | 11:33 PM
  #107
rcoop's Avatar
Originally posted by: rcoop
Are you talking the laser temp sensors ? I have one of those for track and tire temp. I'm talking temp inside the bottle thats where it counts.
Rcoop,
Do you think the standard poly nitrous line is large enough for the volume we are looking for with that high pressure regulator? The Boss low pressure regulator with a single poly nitrous line is good for about 30 hp. If you "T" it at the regulator, then you are good for 60hp.
I would say no or at best you would be at the limit and get inconsistant hits. Its funny after we talked earlier Marky i found a magazine at the newstand with an article on it. Its under the the ZEX brand but it is PSI new regulator.
Old Aug 22, 2006 | 11:49 PM
  #108
Rcoop,
I would expect more of that for sure. You and I have talked with the regulator guy, and he is probably happy to take all the other calls generated from this thread.
Old Aug 23, 2006 | 12:17 AM
  #109
650VIPER's Avatar
I dunno!
Old Aug 23, 2006 | 08:35 AM
  #110
Jed,
Just look at the regulator, if there is a Brass splitter with two nitrous lines and fitting comming out of it, each going to the nozzles, then you are set. If you dont, then you are not getting the full flow, and you simply need to call them for the splitter on the regulator - make sure and tell them that you are running 40 hp.
Marky
