nos setup ?'s
#61
Originally posted by: OregonDunePatrol
This trick with this is knowing which components work with the other components and when you have to step up to quality over price.
#65
Nitrogen[img]i/expressions/face-icon-small-wink.gif[/img] If you flow that much. Most nitrous stuff i know bottle and vavle wise was designed for a lot higher then 20-50 horsepower hits this quads use. So even restriced flow from temp drop is not a problem. Its all in proper selection of your parts.
#67
Well, i did some......ehem....research. And found out that for one, the high pressure regulator that is being sold is good to about 70 degrees. So for it to be effective, you must keep bottle pressure above that point. In these here Utah hills, thats almost a virtual impossiblity. I can guess, if you were to heat it to about 120 degrees to start a run, by mid run you would reach that 70 degree mark, and go rich from there.
I will be looking further into this.
#68
So how are you using Nitrogen? Ok, Ive got my learner helmet on - Teach me!
#70
Nope. Why do you think the Promod and Nitrous Prostreet cars run mutilple bottles for a 6 second run. They are not all nitrous, but you can push with another nitrous bottle to control the temp drop in your main bottle. Nitrogen just works better.
