Vortex rev box vs. Ron woods rev box for the ds
Old Sep 15, 2006 | 10:42 PM
nathanpri08's Avatar
Default Vortex rev box vs. Ron woods rev box for the ds
Which is better in your opinion.Give me some pro's and con's if you have any.Thanks
Old Sep 16, 2006 | 12:00 AM
DragonDJ11's Avatar
Both are excellent CDI's. The benefits to the Vortex are multiple curves, rev limits......Con more expensive then RWR.....The RWR is very good, no switches and cost less then the Vortex.
We own both, and run them on seperate DS's. Good Luck
Old Sep 16, 2006 | 12:04 AM
Hey big gun is a procom rev box but ive never heard anything bad about them.Is there a risk in getting a big gun.Or do i need to just get the ron woods.Also i curently only have a k&N w/outerwears.It wont hurt anything to get a ron woods rev box will it.
Old Sep 16, 2006 | 03:30 AM
ds650ctracing's Avatar
Go with Big Gun or RWR or vortex - Avoid the procom box, An aftermarket CDI will not ad HP to a stock engine, but it will eliminate that annoying rev limiter, I currently run RWR and have had no issues.
Old Sep 16, 2006 | 04:13 AM
DragonDJ11's Avatar
I have not ran the big gun, I am a firm believer in you get what you pay for. However, I do know that there are a lot of them out there running, so take that for what it is worth. I have heard of a few, and let me stress a few going bad. But none have caused the problems of the procomm. Whether or not it adds HP is hit and miss around here, I have heard both. I do know that the stock curve, and the performance curve on the Vortex gives me about 500-700 additional RPMs on Banshee Hill in Winchester Bay.
Also, the CDI will be fine no matter what one you choose on a stock bike all the way up. However, with the stock valve springs you will want to keep your RPMs below 8500. Vortex gives you a rev limit of 8900, and RWR has no limit. We currently run RWR on two DS's with stock springs with no issues, and I ran my Vortex on them for awhile also. You should be all good to go, but if it were me I would get a pipe or at least an endcap first.....But that is just me
Old Sep 16, 2006 | 11:33 AM
I will probably get a hmf slip-on and the ron woods cdi.And then rejet.I havent rejeted my ds with the k&n yet.
Old Sep 16, 2006 | 12:21 PM
Teebone56's Avatar
I prefer the Vortex because of the multiple curves.and to be able to switch between 2 with a flip of a switch...my 2cents.
Old Sep 16, 2006 | 01:34 PM
Goodsound's Avatar
Set a New OEM chassis 4 stroke national record on his OMW DS855 - 3.93 !
I have the Vortex, but it is reprogramed with the the woods curve with different rev limits. So I guess I got the best of both worlds.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 16, 2006 | 05:57 PM
DuneRider650's Avatar
I ride a little here and there......
On the vortex is it possible to set the rev limit on it to say 8350 or something like that....just incase you overrev it somehow you still have safety not like the woods box where it would just keep revving??? or does it only come in a preset limiter.
Old Sep 17, 2006 | 01:21 AM
Goodsound's Avatar
You can set the rev limit to what ever you want with the right software.
