can-am800 vs sportsman800
#61
Originally posted by: brpbear
Bryce GTX are you a flat lander or do you live in the west wear we have real hill we call them mountains out hear some times you will go down hill for five miles or more and have to stop or turn when you get down. It takes a real rider to do that on a Polaris because on a popo you have to hold the brake and give it gas at the same time. Their was a time when Polaris had a performance advantage and bring them down was almost worth it but when the VEE-TWIN came out they lost that.
You guys have yet to answer those points.
#62
Originally posted by: Cardiac
Bryce GTXX
The Sportsman is older. It has never tossed me. It may be unfair to compare it to a newer Outie. Now, what is this 'technical' stuf that you are talking about? Anyone who has been there, done that on an ATV knows that steep technical downhill riding is the hardest. I am sorry, but the fact that Polaris only has two rear wheel engine braking takes it out of the equation for me and many others. I believe the Polaris should stay on the farm with the Honda's. To each his own, but if you were to have time on both machines, you would have to have a wierd agenda to pick a Polaris.
And by the way...all my equipment is well maintained and in top condition so let your imagination roam free......
Bryce GTXX
#63
It seems that some people are having a difficulty understanding my "techo-babble". So lets bring it down to real world terms.
Here is my first point. Your front tires, one or both slip every time you turn a corner while you are in 4WD on a BRP, but that does not happen on a Polaris.
When you drive your quad around a corner, your front tires must turn faster than your rear tires. The reason is, that they travel a further distance than the rear tires. If you need to be convinced of that, take your quad onto a dirt area where you can clearly see the tire tracks. Drive in a circle and compare where your front tire tracks are in relationship to your rear tires. For simplicity, compare only the ouside rear track to the outside front track. You will notice that the front tire track is always outside the rear tire track. Since front tire has to go a further distance in the same amount of time, it must spin faster
Now when lock your front and rear axles together with a 4WD system like BRP, it is clear that the 4WD will not allow the front and rear tires to run at different speed when you turn a corner. Since your rear tires will probably have the greater traction, one or both of your front tires will slip. It is just a fact of life. No arguments. It happens. The Polaris system does not lock the front and rear axles together, so its front tires are allowed to run faster so they don't slip.
So maybe you might think.. yea, but my front tires are still pulling through the corners because they are locked to the rears. You couldn't be more wrong. It is just the opposite!!! The rear wheels are trying to slow down the front tires through the 4WD system. Now the engine is trying to apply torque to the rear tires and the front tires are trying to apply torque to the rear tires, it should be clear that there is no way the engine can apply torque to the front tires!!
Interestingly, in a BRP in a corner in 4WD you can apply no engine torque to the front tires till the rear tires start slipping. Furthermore, your front and rear tires are actually fighting each other in every turn (wasting power). By the time you start applying torque to the front tires, all your tires are slipping in the corner. Given that one or both front tires are slipping in every corner, it clearly must have some affect on your ability to steer through the corner.
The Polaris system on the other hand allows both front tires to turn at the speed that are suppose to turn in the corner. The advantage you gain is that you always have both your front tires to steer with. It is only when the rear tires start slipping, then torque will be applied to the front.
The next time you guys suggest that the Polaris system is bad because the rear tires slip before the front. Just go around a corner. However, you should not feel alone. All manufacturers 4WD (except Polaris) systems do the same thing.
#64
OMG, LOL, I can't believe you just wasted sooo much time talking about something so irrelevant; how a 4x4 system works turning a corner???????? OMG do you stay up at night thinking about this stuff???LOL
#65
Bryce GTX. I think I know what you are trying to say. I believe you are wrong. If my Polaris is in 4wd and I am trying to negotiate a twisting technical trail, it is almost impossible to control when the system 'locks'. You are right, there is a difference in radius in a turn for all the wheels. When locked the Polaris simply wants to go straight and it takes a lot of strength to do otherwise, similar to any other 'locked' 4WD. In the same situation, the Outie delivers power to the wheel with the most traction allowing the other wheel to over or under ride the rotation depending on the situation. It makes steering a breeze and control effortless. To me, it feels like the Polaris is either in 2wd or 4wd lock (if the rear wheels are slipping) with no middle ground. The steering on the Outie feels like it is in 2wd all the time with no control issues. Any which way. I will take the Outie and smile and you can continue to defend the Polaris but I feel you have a small audience. Happy Trails.
#66
Originally posted by: mrtwostroke
hey 800 twin efi polaris does have 4wd in reverse if you push that yellow button that says overide this also gets you full power in reverse. but both of those problems can be fixed easily with some quick wiring. just like you have to eliminate the ignition retard on a yami when in diff lock. and some others but i'm not sure
But I didn't think it engaged the 4x4. Mabye I am mistaken. When I have used it I have mashed on the gas pretty good so really I wouldn't know. I'm too busy trying to hang on [img]i/expressions/face-icon-small-smile.gif[/img]
#67
I could be wrong but it seems like if you are talking 4x4 systems, then Polaris would have the advantage when in 4WD, as it is always locked in that mode. This would cause it to crab in corners and in situation where speed might be involved though, so the "open" mode of the Can-Am would be an advantage here. The Can-Am would seem to have a limited slip diff, which is good for snow, slippery terrain and cornering....at speed (you wouldn't lock run your truck with locked diffs on the highway). Personally I would rather have the ability to run in hi mode 4x4 and lock all wheels when I want it manually. I am more into trucks than quads and don't know yet how they differ in 'technical' riding off road. I do own three trucks I run off road, two exclusively. One is a 1994 lifted Ford which I hardly ever use, and the other is a lifted 2002 Land Rover Discovery with Center Diff Lock and lockers, so I do use 4x4 a lot in pretty rough conditions.
I have been following this thread with interest, having just spent $16,000 CDN with tax on a 2007 camo Outlander 800 XT! I bought it because I thought it was hands down the best. Now I am wondering if it is the best at speed and power, but weak in other areas. I have read a ton about frames and CV breaking, belts slipping from taking on water, etc. and warranty being denied because of abuse. I bought my quad to have fun, which means abuse, and I also bought my quad to get me through stuff my big trucks couldn't go, and certainly spent the money on this quad because I thought it could go where other "quads" couldn't go. We'll see.
#68
yes it also does engage 4x4. depending on how old the bike is there is either a awd light on the dash or by the switch or a little picture showing you the 4wd is engaged. when you put in reverse these lights or pictures will go away but when you push the overide button they will come back. but either way sliminate this you will a much happier rider.
And in my opinion also a polaris 4wd will steer better than. Than other quads in diff lock. the front wheels are allowed to turn at different speeds when turning. That is why they only have one 4wd position. Unlike others who have honda mode and diff lock.
another big advantage on polaris versus kawi (i'm not sure on others). on the kawi you have to drive foward some to get the 4wd engaged. polaris don't have to move at all and you are in. so in situations like heading down a steep hill, and suddenly. You relize there is no more trail a polaris can engage true 4wd instantly to back up.
everyone out there that knows something post how other brands get into 4wd and diff lock do they have to move forward first. just wondering
