Water Wetter etc??
Old Sep 24, 2006 | 11:20 AM
raidermike67's Avatar
Default Water Wetter etc??
Anyone have any experience with using coolant additives to help your ATV's run cooler? I see a few different products available I'm curious what anyone else might be using and if you've noticed any difference? I guess with fall/winter coming shouldn't be a real problem but the summers here get very hot.
Old Sep 24, 2006 | 12:13 PM
Teebone56's Avatar
I use engine ice, I think it keeps it cooler.
Old Sep 24, 2006 | 01:02 PM
TBAS's Avatar
I use 40 below made by Pro-Blend. This replaces the antifreeze. It works great for me.
Old Sep 24, 2006 | 01:19 PM
TheStir's Avatar
Started riding ATVs in 1974!
What I do that has helped a lot, at least as much as engine ice, is the following.
Water transfers heat better than antifreeze, but pure water has a high freezing point and will cause corrosion. So the higher the antifreeze ratio the poorer the heat transfer. I use 1/3 antifreeze to 2/3 distilled water and add the Redline Water Wetter. This offers full protection from corrosion, and down to 0 degrees for freezing, it also hase a lower viscosity so your water pump will have a eaisier time as well.. Doing this instead of a stright 50/50 of antifreeze dropped my temps by 15 degrees while riding my DS. The only time my fan has come on since I did this was on the dyno.
If you need protection below 0 degrees, use a chart that shows the ratios to get to the freezing point you need.
Scott
Old Sep 24, 2006 | 02:08 PM
Good info, it NEVER freezes so that's not an issue. Increasing my water ratio should help me run cooler??
Old Sep 24, 2006 | 03:02 PM
bombrider04's Avatar
I also use engine ice its some pretty good stuff you can get some at rockymountainatv.com
Old Sep 24, 2006 | 04:11 PM
choosetolose04's Avatar
[img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 24, 2006 | 09:09 PM
FatHolly's Avatar
Engine Ice here... love it.
Old Sep 24, 2006 | 09:10 PM
DragonDJ11's Avatar
Old Sep 25, 2006 | 12:21 PM
DuneMe's Avatar
I run straight distilled water and water wetter. . . no coolant. I don't have any freeze protection so, have to watch it when I go on trips, etc. It doesn't get cold enough around here to freeze where the bike is stored.
I don't have a temp gauge and my trips can have wide swings in ambiant air temperatures so, I really don't think I can say how much the coolant temps drop.
The heat transfer for straight water is MUCH better than for water / coolant mix so, I know I have better cooling. I will probably drain here in a couple weeks and fill with a mix as I see a few colder weather trips that could see and issue.
