Going Back!!!
#42
Originally posted by: DSNUT
Based on the math, your chassis would have to weigh in at a little under 170 lbs to run a 4.2 with 67 hp........assuming a 135 lb pilot.
I need to find out who your chassis guy is since a motor weighs about 117 (assuming we are still talking about a Rotax). That leaves 53 lbs for everything else[img]i/expressions/face-icon-small-happy.gif[/img] That is incredible![img]i/expressions/face-icon-small-smile.gif[/img] Great job!
After a little more research, I have seen weight claims from 105 to 112. The most confident and well versed claim was 112..........on a stock 650 motor.
Originally posted by: rcoop
Well good job guys those are impressive numbers. Put them on the track and lets see what they run. If my 67hp can run 4.2 with a pilot then you guys should be setting some serious records.
I know the DS motor felt like 200lbs to my back
#46
Ok, so you took the starter off. Lets say your motor weighs in at 80 lbs just to be conservative. That chassis must be SICK light!![img]i/expressions/face-icon-small-smile.gif[/img]
I second 1Big's request. I would love to see some pictures of this setup. 4.2 with only 67 hp is simply unheard of!
Scott (Choosetolose) - Did you read this? We have a stock bore, stock stroke DS650 without NOS at 67 hp that ran a 4.2. Didn't you run a 4.6 with around 80 hp at 290 lbs? Sounds like you have some catching up to do for the stock bore times[img]i/expressions/face-icon-small-wink.gif[/img]
#47
#49
That sounds reasonable[img]i/expressions/face-icon-small-wink.gif[/img] How much lighter do you think a DS can get?
I think a titanium rigid with an external starter will go near 210lbs.
#50
I dont know about that scott. The 450r gas tank bike was around 190lb.. Our motor is much heavier. IMO a TI drag chassis will get you near 260- 270 lb/ with no battery and tiny radiator.
I need to see how much the green goblin weighs, The subtract about 20 lbs off chassis for titanium.
