paddle help
Old Oct 19, 2006 | 11:32 PM
DS22's Avatar
Default paddle help
hello im new here
just had a question about paddles i have been using 20/10/10 8 paddle haulers
i want to go to 22/11/10 haulers but im not sure how many paddles 7, 8, 9 i should get
my bike is a
2000 ds650
ron wood exhaust
ron wood cdi
tm 45 carb /ported intake
ron wood 60% clutch springs
twist trottle
works shocks
15/40 sprockets
mohawk front tires
Old Oct 19, 2006 | 11:51 PM
shmee's Avatar
Default paddle help
what mostly do you do? hills? flats? drags? how much do you weight?
Old Oct 20, 2006 | 12:02 AM
DS22's Avatar
Default paddle help
i live right by little sahara ut i like to run up the big hills
Old Oct 20, 2006 | 12:15 AM
duneittilludie's Avatar
Default paddle help
From your description of your riding (big hills) i would say that a 9 paddle extreme hauler would be about right.The 22" will be much better than the 20" you have been using.
Old Oct 20, 2006 | 12:24 AM
DS22's Avatar
Default paddle help
do extremes have taller blades ?
i hope i can get more speed out of 22 the 20 's suck
Old Oct 20, 2006 | 01:13 AM
DragonDJ11's Avatar
Default paddle help
For you I would suggest going with the 10 paddles. We have a DS with those same basic mods and the 10 paddles were awesome for that one, in Lt Sahara. I would also suggest adjusting your gearing more. Go with at least a 15/42 with that setup, maybe even the 14/42. Also get the black lable rims over the red lables. My thoughts, those worked good for us.
Old Oct 20, 2006 | 01:47 AM
Fastestdad's Avatar
Default paddle help
If you are heavy at all then like they said get the 10 paddle extremes. The DS is a big heavy torquey bike. Also 8" rims will have a little better bite off the line and expand quite a bit when rollin fast basically like having a higher top gear. They just dont handle as well if you like to slide or side hill.
Old Oct 20, 2006 | 01:50 AM
DragonDJ11's Avatar
Default paddle help
Are you referring to the paddles or the smaller rims, or the number of paddles being different?
Old Oct 20, 2006 | 09:09 PM
DS22's Avatar
Default paddle help
thanks for your help
im 6ft 185 lbs
im a little worried that 10 blades will be to much paddle .
i have 2 sets of douglas black label 10 inch wheels
what gear are you climbing sand mtn with 14/42 gear and 10 paddle extremes?
Old Oct 21, 2006 | 01:37 AM
DragonDJ11's Avatar
Default paddle help
My brother was pulling it in 3rd gear and he weighs in at 220ish. The thing that I noticed there was that you have very soft sand, and it is very dry also. That allows for a lot of spin. I thought the 10s were a little better hooking up the our 8s or 9s...
