different fan question, mine won't shut off...
Old Dec 15, 2006 | 06:49 PM
dondiesel444's Avatar
Default different fan question, mine won't shut off...
as soon as I turn my key on, the fan comes on and never goes off while riding until I turn the key off. I'm guessing it's a sensor, but anyone know which one? I know most guys complain off the fan never coming on.
Old Dec 15, 2006 | 07:43 PM
bombrider04's Avatar
well then it sounds like the temp sending switch is stuck allowing current to get through or somehow it may be crossed with something else. Try letting the quad cool down and once its all the way cool try turning the key on again and see if that works.
Old Dec 15, 2006 | 08:08 PM
the quad can sit outside for a week and as soon as I go turn the key on the fan comes on. I'm guessing the sending switch is bad but I don't know which one it is...
if I unplug it the fan should go off, correct? but where is it?
Old Dec 15, 2006 | 09:45 PM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
Should be no prob. Go in and look at the wires comming from the fan to the thermostat area. There will be 2 female wires connected to your temp sensor. Un-plug one of those wires comming off your fan and then turn on key. The fan should not come on.
Then you can bypass the thermostat sendor and go to checker auto and get a $2 toggle switch. They have them that are ready to plug RIGHT in. You can drill a little hole in the side if gas tank cover and install toggle switch, So when you are riding heavy you can run with it on at all times with the flip of the switch. Good luck.
If you look closely at pic #4 in my page you can see a little alum switch right above my temp guage. That is where my toggle used to be. No need to run or connect any new wires.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 15, 2006 | 11:20 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Its located right on the theromstat housing it could be bad but my guess would be the fan relay its burnt shut unplug the sensor wire then if it conttinues its the relay simple.GOOD LUCK
Old Dec 16, 2006 | 10:34 PM
thanks for the help guys, I'll check it out tomorrow!
Old Dec 17, 2006 | 12:44 PM
alright let us know how it works out
bzdok1234
30
Feb 23, 2016 01:55 PM
robert301972robert
Aug 30, 2015 11:34 AM
ScopeZ_
Jul 28, 2015 01:44 AM
200es
Jul 10, 2015 09:09 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
