my sprocket needs
Old Jan 19, 2007 | 08:02 PM
2006ds650xrider's Avatar
Default my sprocket needs
okay i want to know what the best sprocket setup for me is.
sprocket size front and rear, chain size type,( alum, steal, ect).
im 220 lbs, i ride mostly trail and some sand.
60% just cruising, 10% playing around, 30% hualing @$$.
i have 20x11x10 Sand Shark for the dunes and 22x11x9 Razr rear, 23x7x10 Razr front for the trail.
thanks
Old Jan 19, 2007 | 08:12 PM
bombrider04's Avatar
well I would suggest the 520 conversion for the chain to lose some rotating mass but it sounds like you don't need it...I would suggest around 15(f) to 40(r) or a 16-40...the only downfall if you did want to go with the 520 is I heard that it will stretch easier compared to the heavy duty 530...I know my 530 is a 110 chain, but they changed the sizes of the swingarms since then so I am not sure what size you chain is...I ride mostly traisl so thats the gearing I like personally but someone may be able to help you for when you go to the dunes since I don't really have too many places to open her up.
Old Jan 20, 2007 | 02:06 AM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
going with the 520 conversion is a great set up sidewinder will set you up with the correct gearing also. And for the sand if you go with a set of 22" 8 paddle haulers you will see a huge differance in the way your bike runs in the sand it is money well spent.
Old Jan 20, 2007 | 05:03 PM
MrMeaner's Avatar
I would go 15/40 530 and be done. I dont think the 520 would help you much in the type of riding.
Old Jan 20, 2007 | 07:18 PM
hey thanks for the help you guys.
im gonna go with the 15/40 tooth and keep the 530 chain.
and i will buy 22' haulers for my next sand paddles.
but also which type of metals work best for a longer period of time?
ive heard that the aluminum ones dont last.
thanks again,
brent
Old Jan 20, 2007 | 10:47 PM
nathanpri08's Avatar
Whats stock gearing?16/???.I put a 14tooth on the front and its alittle to torqy.Plus top end is not very good around 65mph or so.But getting there it hauls a**.The only thigs i have are razers and k&n w/outerwears,sandsharks.It was an impressive diference with a 14 tooth.I never really go over 60-65mph anyway.I think im going to a 15tooth.Got mine from rockymtatv.com for like $8.00.
Old Jan 20, 2007 | 11:24 PM
pipelayer's Avatar
I'm a Plumbing contractor and I have some old friends that always called me Pipelayer for some reason?
stock is the best for all around and alum. dosent last. just my 2 cents
Old Jan 21, 2007 | 02:34 AM
stugots's Avatar
Yup I ordered a 15 front and a 40 back steel 530 from rocky mountain both shipped for 33.00. hell of a a price. The front is on close out for 7.95. the rear 18.00
I tried to get a 15 out at Glamis and they wanted 45.00
Old Jan 21, 2007 | 07:06 PM
DragonDJ11's Avatar
Ok, I am guessing you ride little Sahara in Utah the most? My question is if you ride sand way more, at your size I would look into a 15/42 gearing mayby even 15/44 for your hills there....Seth I know you are lighter, but what gearing were you running on your bike there? If you stay with the 530 chain, an alum rear sproket was lasting us around 70-100 + hours of riding. The 520 alum was about 20-30 hours. Again if you are running mostly sand I would recommend the 520 conversion it does help. I was weighing in at 300lbs and the 520 conversion gained me 300-500 rpms at little sahara. Also when you get your 22" haulers I would recommend the black lable rims. Much lighter then the red lables and still very durable. Just my .02
Old Jan 22, 2007 | 01:27 AM
ya i was wondering how much the douglas rims weighed.
and will i have to trim the heel gaurds for the 22" haulers im pretty close with the 20s
yes i ride little sahara but i ride trails a bit more.
