Battery Output and Capabilities
Old Feb 8, 2007 | 08:30 AM
check's Avatar
Never make a decision before you have to, always have a Plan B, and don't tell me it's not possible!
Default Battery Output and Capabilities
Hey guys, this is all very educational. Any idea how many watts the stator on y wife's new (2007) Eton Viper 90R (4-stroke with reverse) puts out, and whether there is enough to add hand warmers or thumb warmers? (It has two little front lites and rear lites including brake lights, and a lighted gear display, an electric switch to change from forward to reverse, a horn, and a backup "beeper" that goes off when you are in reverse.)
I'd appreciate any advice, thanks.
James
Old Feb 8, 2007 | 11:28 AM
FatHolly's Avatar
Originally posted by: MRDS650
He said he has an 2001 DS650. This would be a model before the baja with only 1 factory light.
I think his stator is rated at less then 240w. the early DS had a smaller stator - correct me if i am wrong ???
No its still 290w... my '02 Standard DS handled the stock main plus 2- 75w trail tech's no problem. I'm pretty sure all year stators are wound to the same wattage.
Old Feb 8, 2007 | 09:19 PM
RUNNINmyDS's Avatar
Hey, after I started this post I was informed that it is the stator capabilities not the battery. So, what I found in the back of my shop manual was Electrical Specs. and in there was the stator wattage. So I would say get yourself a shop manual disc for 5 bucks off ebay and check out the Electrical specs. Then print out the whole book for future use =) Good Luck
-Nathan
Old Feb 8, 2007 | 09:51 PM
check's Avatar
Thanks, Nathan - good idea. In fact, it just happens that I ordered one today, so it must be that great minds think alike, eh?
Or is it that fools seldom differ?
Old Feb 8, 2007 | 10:20 PM
  #15
RUNNINmyDS's Avatar
HAH! Im actually torn. Im no great mind, but I may fall JUST short of a fool. So maybe we can come up with our own little happy median. Just wondering, was it 5 bucks?
Old Feb 8, 2007 | 10:40 PM
  #16
check's Avatar
The dealer said he could probably burn a CD for me, for 20 bucks. (I suppose I could have ordered it from the etonamerica website, but by the time it made it acroos the border to Toronto, it would have been next Christmas!
Old Feb 9, 2007 | 03:14 AM
  #17
RUNNINmyDS's Avatar
LOL true, for 20 bucks at a dealer do it. No need to wait for shipping time or pay the shipping.. By the time its all done your damn near your 20 bucks lol.
Old Feb 9, 2007 | 09:02 AM
  #18
BawgBoy's Avatar
Originally posted by: FatHolly
Lighting capabilities have little to do with your battery. It is all about your stator output... if you tax your stator to the point of needing the power stored in your battery you will be pretty disappointed when you can't get your bike started in the middle of nowhere after dark. Your stator puts out about 290 watts, but the usable range is only about 240 after all the electrical systems on the bike take their share.
To address the second part of your question... you need to choose lights that will keep your wattage under 240. When it comes to lighting you have many options. You asked one light or two... that really does not matter as long as you stay under 240w. When it comes to HID's you again have many options. HID's put out 3 or 4 times the light of a standard bulb of the same wattage. For example an HID that puts out 75-80 watts of light probably only draws 25 watts. You could potentially put something like 9 HID's in that power range on your bike. If you are racing in the desert, or something similar, you may want only one 200+ watt light so that all the bulbs' power can be easily directed, instead of having to aim 9 of the smaller models. Always look at the wattage, and stay under 240w.
TWENTY AMPS worth of lighting? Can't imagine any stator keeping up.
Old Feb 9, 2007 | 12:21 PM
  #19
FatHolly's Avatar
Take a walk with me into the world of Can-Am and BRP, where there is a mythical bike known simply as the DS, where yes that kind of big boy amperage is not only possible but easily attainable. The DS stator is rated by BRP for 290 watts... 290w/12v=24.16 amps. Like I said in the original post the stock stator has been tested to 240w.... 240w/12=20 amps. Yes it can handle that much amperage. I have safely run the stock main (65w) and two trail tech aux lights (75w each) that makes a total of 215w @ 17.92 amps. I have ZERO battery draw down, and have had nights where we rode all night only stopping to gas up. I have since taken the lights off because I don't ride that much at night anymore, but when I did have them on, NEVER did my DS ever even studder on startup. We are talking about gas tank draining rides with lights on the entire time even when we stopped to have a rest. Now I'm not taking shots at your '99 Yamaha Big Bear, (or am I [img]i/expressions/face-icon-small-happy.gif[/img]) but the technology in the 21st century is amazing.LOL Here's one that will blow your mind... you can get a rewound stator for the DS that is rated at 400w.... thats 33.33 amps. Now can you imagine a stator keeping up?
Old Feb 9, 2007 | 12:53 PM
  #20
check's Avatar
Hey, FatHolly, do you know how much the Stator is rated for on my '04 Outlander 400 Max XT?
