bomber 400 ho
Old Feb 3, 2007 | 11:17 PM
aballl18's Avatar
Default bomber 400 ho
im lookin a buyin one of these how many things is out there that u can do to them atvs?
Old Feb 3, 2007 | 11:42 PM
Steveo10's Avatar
Plenty! But it also depends on what you want to do? Build 1 for trails? muddin? speed?
Old Feb 3, 2007 | 11:45 PM
aballl18's Avatar
I NO THIS SOUNDS DUMP BUT THAT IS THE DIFFERENCE BETWEEN BUILDIN ONE 2 MUD AND FOR THE TRAILS LIKE WHAT DIFFERENT THINGS IS THERE 2 DO?
Old Feb 4, 2007 | 04:33 AM
Steveo10's Avatar
Will for a example on the trail, you want a tire that can hook up good on dirt or grass. The Renegade comes factory with Holeshot ATR tire. Perfect setup for this bike b/c its meant for trails. They hook up well!!! Almost any Holeshot tire will do.
In mud, if you have enough ponies, you can go with bigger tires (mudlites) to give you enough clearance in the mud. Also you want to look at your quads gearin or clutchin. You mite want to gear down. Also you will have to see how high your air intake is. Might have to make some modz there if factory intake is too low or in a bad spot.
These are just a few examples to clearify for ya.
Old Feb 4, 2007 | 09:25 AM
aballl18's Avatar
WERE CAN I GET A PIPE AND THE GEARS 4 MY RIDE A BOMBER 400 H.O.?
Old Feb 4, 2007 | 07:48 PM
skidoofan's Avatar
I think the only pipe out there for it is a big gun slip on not sure on that though. There are no gears, you would have to put a clutch kit in it. If you go to the other site you will find alot more info. Good luck
Elkaholic
Sep 6, 2015 02:44 PM
Tpsycho
Dec 15, 2006 04:54 PM
Tpsycho
Aug 18, 2006 09:56 PM
CaptainQuint
Jun 10, 2005 09:04 AM
HoundDog06
Nov 16, 2003 12:07 AM
