ds light conversion question
Old Feb 24, 2007 | 01:37 PM
learnem's Avatar
Default ds light conversion question
The plastic piece that goes over the front facia, with the two pins that require holes drilled in the facia is where my problem lies
are there supposed to be screws going into those holes in the pins to keep the pins in the hole, or do they just freeball it there?
what are you guys using to secure them to the facia?
also, i trimmed the front facia beyond the line I drew, using the new plastic piece, and the damn facia is STILL hitting the lamp before I can align the bolts to the bracket off the oil tank. I want to grind it down with a dremel, but I don't want to fack it all up
thanks guys
Old Feb 24, 2007 | 02:28 PM
learnem's Avatar
ok, here is what I did
I put three thick washers inbetween the headlight and the brackets, to backspace the headlight, and it worked out fine.
Old Feb 24, 2007 | 03:26 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
Having done the washer bit, make sure when it gets dark that you take it out and adjust your beam. I bet it hits low. The two new brackets are very flexible and easy to manipulate but if you're still running into clearance problems the bracket that the facia and trim piece mount to can also be bent out some to provide clearance and still have your light shine where you need it. Just a little input from someone who has done five of these conversions...
Old Feb 24, 2007 | 07:09 PM
DuneMe's Avatar
It's been a few years but. . .
Yes, you have to cut the crap out of that thing. Don't worry about it!
Alignment - I didn't have to do a thing.
The posts on the flashing piece are held on by these thin black sheet metal things that have a whole for the post but, are scrolled kinda. Just push them on and all is good.
What else?
Let me know if you need a picture. . . my front plastic is off right now ayways.
Old Feb 24, 2007 | 10:19 PM
MRDS650's Avatar
Canadian and Proud of it !!!
Is there a Bomb part number for those things that hold the pins into the facia ??
Old Feb 24, 2007 | 11:01 PM
DuneMe's Avatar
Yep. . .
Oh, You probably want me to find that now?
Hmmm
I'll have to look around a little and see if I have anything with it on there.
Don't hold your breath!
Old Feb 24, 2007 | 11:17 PM
MrMeaner's Avatar
I order the headlight trim and the dealer got me the jam nuts also
Nazz26
Jul 30, 2015 11:51 AM
KingDingalling
Jul 29, 2015 10:55 AM
DeFox500
Jul 26, 2015 06:32 PM
toonces
Jul 11, 2015 12:01 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
