throttle cable lube
Old Apr 2, 2007 | 08:04 PM
worker10's Avatar
Default throttle cable lube
I just got a new throttle cable for my 46hv and was wondering what kind of lube to put on it, if any? Do you guys usually use some sort of penetrating oil or a graphite lube.
Old Apr 2, 2007 | 08:21 PM
dznutz's Avatar
wd40[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 2, 2007 | 08:24 PM
worker10's Avatar
Thanks, I didn't want to waist money on some special lube if it wasn't necessary.
Old Apr 3, 2007 | 01:30 AM
MRDS650's Avatar
Canadian and Proud of it !!!
I use Cable Life ( I think that what it is called), Comes with the special tool for getting the lube into the cable.
Old Apr 3, 2007 | 01:32 AM
HeadsupRacing's Avatar
How well does this work?
Old Apr 3, 2007 | 01:39 AM
MRDS650's Avatar
Very good, it basically directs the lube down the cable. I find it works even better if one end of the cable is off and it can be held up in the air, so that the lube flows down !!!
Old Apr 3, 2007 | 01:40 AM
Im just curious as to how well it does compared to wd40 or jb80 when used in the same manner.
Old Apr 3, 2007 | 10:38 AM
MRDS650's Avatar
I have not used JB80 before, but i do think it works better then WD40. I found WD40 works good but does not stay around long to do the job. Other wise I had to lube my throttle cable at least twice as often with WD40 compared to cable life.
Old Apr 3, 2007 | 04:28 PM
01ds650's Avatar
I have NEVER lubed my throttle cable. Should I be doing this?
Old Apr 3, 2007 | 10:06 PM
DSRIDER650X's Avatar
same question as above!!! Didn't know about that one!
Thanks
